Front fork seal isuues - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 6 (permalink) Old 06-22-2013, 05:59 PM Thread Starter
lyfsux's Avatar
Took bike out after the long winters nap. Noticed fork seal leaking took it into the shop as I didnt want to mess with them time or tooling they replaced both sides. Picked it up then my stator went as I was replacing stator notice the opposite side was leaking now. Took it back and they were puzzled but took it right in and replaced it again as i stood and watched small shop that allows customers to be in the area. Now it is leaking again!! and ideas on the cause?
2000 sp1 number 000039
full hindle off-road exhaust
power commander
double bubble screen
sprocket swap 1 down 3 up
k and n filters
and now flapper mod thanks to rc forums
lyfsux is offline
post #2 of 6 (permalink) Old 06-22-2013, 11:17 PM
Quoted: 90 Post(s)
Any nicks or damage to the fork slider from road debris?
Plus, if they did cover the fork slider with tape or such, it's possible the seal lips may have been damaged and started to leak.
I replaced the seals and dust caps on my buddy's SP2 forks with no issues.
post #3 of 6 (permalink) Old 06-23-2013, 12:17 AM
Plain old corrosion happens on the inner tubes as well. I`ve seen it visible when the suspension is unloaded. Check for that. It can cause the leaks. ON, with winter and salt means its viable.
post #4 of 6 (permalink) Old 06-23-2013, 06:55 AM Thread Starter
lyfsux's Avatar
Thanks for the replies, The chrome looks in great shape and no tape was use in the install. The inner tube was not checked that could be a possibility. Is that just a clean up that can be done on the bike after sliders are removed? Any suggestions on anything else it could be as I would like to address this the next time he has them apart as I feel that I will be paying for it this time around. Over filling the oil wouldn't cause this issue would it?
power commander
k and n filters
lyfsux is offline
post #5 of 6 (permalink) Old 06-23-2013, 11:48 AM
The fork tubes need to be checked for runout...did they do this?
post #6 of 6 (permalink) Old 06-24-2013, 12:26 AM
What brand of seals????
Yes, over filling the oil would be an issue.
I'm always right.
2011 Bike of the Year
