New to me rc51 sp2 - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 75 (permalink) Old 02-03-2014, 01:38 AM Thread Starter
New to me rc51 sp2
well, here she is. 2002 honda rc51, 17,xxx miles, former track bike. I payed $1400 for it. Knew it needed some superficial work, but the PO said all the important parts (engine, susp, brakes, etc...) were solid. got it home and stripped the fairing right away. they are track fairing although the upper fairing does have a single headlight. the bottom fairing is pretty ratty, so it's getting trashed. the tail fairing is good, and the upper fairing might be salvageable. as far as mods, the only thing i see is a jardine pipe (which sounds like satan himself, love it!!) and a pc3. also i know he had the susp set up for him and better brake pads.
first off, i'm going to do routine maintenance. change oil/filter, spark plugs, flush and put in new brake and clutch fluid, new coolant. tires are good, chain has some surface rust (going to see if it will clean up) and i'll check the sprockets and brake pads tomorrow.
next, will be some of the free mods. and maybe new oem air filters if it needs them. going to tear it down/inspect/give it a good scrubbing tomorrow.
several things i noticed right away is the shift lever needs to be changed (its bent) undertray for the battery needs to be bolted back up (it's drooping)
now, it had an issue with water leaking into the tank during a rain storm, so i drained the tank the best i could (since it was in the rain on the way home) i noticed there is some slight rust spots on the inside of the tank (not sure if you can see in pic) is this going to be an issue, should i splice an inline filter on the fuel hose?
i put a little gas in it, charged the battery and it fired up. sounded good, revved clean, idled good.
i downloaded the owners manual, and i know how to use the search function. that being said, i might ask questions from time to time if i'm looking for a specific answer.
any comments, opinions, advice?
thanks, nick
thaddeus is offline
post #2 of 75 (permalink) Old 02-03-2014, 02:06 AM
That poor bike looks a bit neglected but it's in good hands now.
You'll definitely need this
to help you find your way around technical challenges in the future.
Like you said, change all the fluids and my advice would be to check all the electrical connectors for corrosion on their terminals. Use a pinch of dielectric grease before you plug each one back on.
That way you can eliminate a possible future system failure that might occur.
Any idea what is that white residue on the left side of the frame?
post #3 of 75 (permalink) Old 02-03-2014, 02:11 AM Thread Starter
it does indeed need a good scrubbing, i think it will clean up quite nice.
not sure, soap maybe? it wipes right off though.
good idea on the dialectric grease, do you just put it inside the connectors?
thaddeus is offline
post #4 of 75 (permalink) Old 02-03-2014, 02:15 AM
Yes, with the tip of your finger so that when you plug it back in, you see the grease squeezed out of the connector.
Just to correct you on the title, this is an SP1 and not an SP2. You can tell it from the swingarm and the cooler fan tepm. switch mounted on the LH rad and I bet if you measure the throttle bodies I.D you'll find that they are 57mm and the injectors have 4 holes each.
post #5 of 75 (permalink) Old 02-03-2014, 02:57 AM Thread Starter
the title says 2002
the sticker on the frame with the vin says it was made 2/02. it has the 6 spoke wheels of the sp1 (from what i've read.) has gold rotors though. i really hope this bike isnt pieced together.
did they make the sp1 in early 2002? that's a little bit of a bummer
thaddeus is offline
post #6 of 75 (permalink) Old 02-03-2014, 03:47 AM
COBRA90GT's Avatar
Quoted: 49 Post(s)
Instead of adding an inline fuel filter to the fuel hoses (because you plan on going through the bike anyways, correct?), remove the fuel tank, remove the fuel pump (the assembly houses the fuel filter) and replace the fuel filter with a new OEM fuel filter (any microfiche OEM parts supplier should do).
YMMV
'06 Black/Metallic Gray RC51
-Competition Werkes FE w/
Clear Alternatives IT
'02 Silver/Black CBR 954RR
COBRA90GT is offline
post #7 of 75 (permalink) Old 02-03-2014, 03:51 AM Thread Starter
YMMV
i plan on it. i'm just slightly worried about the rust spots, it's not bad, but still.
thaddeus is offline
post #8 of 75 (permalink) Old 02-03-2014, 04:28 AM
the title says 2002
It may say 2002 but the bike is SP1. I didn't say it isn't a 2002 model. Maybe imported in 2002.
Anyway, use your engraved VIN number, which is located on the steering stem part of the frame and decode it here
http://www.analogx.com/contents/vinview.htm
...and see what year it says it is.
Alternatively you can give your true VIN (not the side plate on the frame) to a Honda dealer and verify it through Honda network.
But the frame is indeed SP1 and you can tell by the welding seams of the engines mounts.
SP2 frame to compare
post #9 of 75 (permalink) Old 02-03-2014, 10:42 AM
That is definitely a SP1 swinger, and those are definitely SP1 radiators with the SP1 thermoswitch.
Like Makis said, look at the engraved serial number on the neck. What's the 10th digit? Y is 2000, 1 is 2001, 2 is 2002 and so on...
post #10 of 75 (permalink) Old 02-03-2014, 11:02 AM
The forks are sp1 as well. The undertay looks to be sp1.
The subframe is and RVT1000R1. That means either 00 or 01.
My guess is the frame is sp2. I can see sp2 engine mounts.
I'd say the bike is an sp1 with sp2 frame. Not surprising. Someone crashes an sp1 and needs a new frame. Buys an sp2 and swaps the bike over. Pretty basic stuff.
