254 temp in less than 10minutes - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 66 (permalink) Old 05-31-2014, 07:13 PM Thread Starter
Ram51's Avatar
So I went to go fill up at the gas station (please note it's my first ride since last June) and by the time I was done and on my way home, the motor was blinking 254degrees with the oil light on!
My first track day is suppose to be June 16th and I want to be able to make it without my bike falling apart!
It has a fresh oil
Change, in fact that's the first ride since I changed the oil. Noticed some fluid well spread out on my lower fairing, the fairing collected the fluid. Not sure if it's coolant or oil.
What else could go wrong?! Ahh! Does anybody have any ideas?
Sent from Motorcycle.com App
Ram51 is offline
post #2 of 66 (permalink) Old 05-31-2014, 07:19 PM Thread Starter
Ram51's Avatar
So it's a pretty big coolant leak. But why would my oil light be on solid light no blinking, while I was riding?
And why does it only leak when The bike is on or if I'm riding
Ram51 is offline
post #3 of 66 (permalink) Old 05-31-2014, 07:42 PM
weyrauchrc51's Avatar
Quoted: 10 Post(s)
Check your coolant hose connections at the radiators...they could be expanding when the hoses heat up causing the leak. Happened to my SP1, all I did was tighten up all the connectors and problem solved. Also make sure your fuse for your fan is working, fan is kicking on right? I only mention it because I also had a blown fuse for the radiator fan.
2001 SP1 (sold)
2004 SP2 (properly stored)
2012 Ruckus (stolen)
Semper Fidelis
weyrauchrc51 is offline
post #4 of 66 (permalink) Old 05-31-2014, 08:08 PM
Any oil light is not good. Read the service manual to decode what solid versus flashing means.
post #5 of 66 (permalink) Old 05-31-2014, 08:10 PM Thread Starter
Ram51's Avatar
Haven't checked to see if both radiators are on. I did hear them running though, is there a way to check and see if they work without having to leave my bike running til it gets hot?
Haven't inspected behind the radiator or any of the hoses yet. Still waiting for it to cool down.
What about my oil light being on? I have a fresh oil and an oil filter in there
Ram51 is offline
post #6 of 66 (permalink) Old 06-01-2014, 01:11 PM Thread Starter
Ram51's Avatar
I'm not really sure where to start with these radiators.. Am I suppose to remove them and see what's leaking through the back?
Ram51 is offline
post #7 of 66 (permalink) Old 06-01-2014, 07:35 PM
COBRA90GT's Avatar
Quoted: 47 Post(s)
^ First remove both fairings to see if you can find dried up spots of coolant residue near the radiators or at a hose connection somewhere.
If the leak spot(s) is not obvious, then add coolant, start the bike up, allow it to idle for several minutes while it gets up to temp and monitor all radiator hose connections/radiators to see if the leak point can be identified.
You can always try a cooling system pressure test kit or let a reputable shop take a look at things to sort out your bike since you will be putting it on the track pretty soon (?).
G'luck
'06 Black/Metallic Gray RC51
-Competition Werkes FE w/
Clear Alternatives IT
'02 Silver/Black CBR 954RR
COBRA90GT is offline
post #8 of 66 (permalink) Old 06-01-2014, 09:08 PM
92VFR's Avatar
Quoted: 18 Post(s)
G'luck
The cooling system is important, but you need to find the source of the oil light problem first. Overheating will damage your engine, but it will take a while to get that hot. A lack of oil pressure will destroy the engine in seconds.
92VFR is offline
post #9 of 66 (permalink) Old 06-02-2014, 09:01 PM Thread Starter
Ram51's Avatar
Lack of oil pressure? As in loose oil pan bolts or loose oil filter? Just those two possibilities?
Ram51 is offline
post #10 of 66 (permalink) Old 06-02-2014, 09:27 PM
Lack of oil pressure as in
  • No oil
  • low on oil
  • clogged oil journal
  • sending unit faulty or not connected
  • oil pump is no good.
Perform an oil change just to get fresh oil in the engine.
Good luck.
