PC3r on 06 RC51 - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 5 (permalink) Old 09-10-2014, 07:39 PM Thread Starter
PC3r on 06 RC51
I bought a pc3r of ebay and Im having problems with the male end of the bikes harness mating with the female end of the PC3r. The male PC3r connects just fine with the bike.
I contacted PC in Las Vegas and they said the 105-310 part would connect with my 06 RC51. Visually there appears there are extra guide posts in the corners of the male bike connection.
Anyone else with an 06 that had a similar problem? what part # PC3r are you running
MC
crj900pilot is offline
post #2 of 5 (permalink) Old 09-10-2014, 09:46 PM
It should fit just fine. Can you take a picture of each of the PC connectors (end on) and also the bike connectors and post them?
TXFireblade is offline
post #3 of 5 (permalink) Old 09-10-2014, 10:23 PM Thread Starter
[ATTACH]Click image for larger version
ID:	68993[/ATTACH] The first pic is the bike. there appears to be extra male guides in the corners of the bike plug. your help is appreciated
post #4 of 5 (permalink) Old 09-10-2014, 11:03 PM
I just compared the connectors in the pictures with the ones on my bike (2003 and PC3R) and everything looks identical. The one thing I can see is that the black seal in the left connector of picture 2 actually belongs in the recess of it's mating socket. One easy way to tell is to join the two connectors on the PC to see if they fit. Obviously the two bike connectors fit together OK since that is the stock connection.
There should be 5 keys on the plug (the thing with the exposed pins) and 4 keyways on the socket. The largest of the keys goes to the largest of the keyways, the two keys opposite each other across the widest dimension of the connector go together and the two keys on one edge of the plug mate with the single wide keyway.
Hope this helps
post #5 of 5 (permalink) Old 09-10-2014, 11:45 PM Thread Starter
I owe you a beer fireblade, I removed that black seal and it fit. Good eye!
