Fuel in pipes - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 7 (permalink) Old 04-29-2015, 04:26 PM Thread Starter
Fuel in pipes
Hello all,
New here. I have a 2001 51 and bought it new. Its been in the garage for the past year and a half sleeping. Well I put the charger on it and fired it up, started right up so I warmed it up and was going to ride it to get some fresh gas in it. Shut it off and got my gear on and went to start it and it would not start. It was leaking gas out the bottom of the cross over pipe on exhust . Got it Started again but had to hold the throttle open and it run but die if I closed the throttle.
Any Ideas?
Thanks
BrittRC51 is offline
post #2 of 7 (permalink) Old 04-29-2015, 04:29 PM
Quoted: 82 Post(s)
FPR...... hth
dansp1 is offline
post #3 of 7 (permalink) Old 04-29-2015, 05:29 PM Thread Starter
When You say FPR and HTH what does thet stand for?
Thanks dansp1
post #4 of 7 (permalink) Old 04-29-2015, 05:38 PM
extrapolator's Avatar
Quoted: 99 Post(s)
FPR = Fuel Pressure Regulator
HTH = Hope This Helps
He's a man of few acronyms.
extrapolator is offline
post #5 of 7 (permalink) Old 04-29-2015, 06:22 PM Thread Starter
Ok Thanks guys. Will check it out.
post #6 of 7 (permalink) Old 04-30-2015, 02:23 AM
BritRC's Avatar
Sounds like FPR, but could also be a sticking injector if the bikes been laid up a while. Check the FPR first it's quick and ray to do, plenty of posts about it.
Good luck.
2001 RC51 SP1 (modified)
2007 GSXR1000 K6
1994 CBR600 FR (very modified)
BritRC is offline
post #7 of 7 (permalink) Old 05-10-2015, 06:10 PM Thread Starter
Just wanted to say Thank You to all of your suggestions. I replaced the FPR ,new plugs and fuel filter, and changed the oil and filter. It's running the new. Thanks again.
