Battery issue - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 17 (permalink) Old 05-25-2015, 03:43 PM Thread Starter
Wiffer's Avatar
Quoted: 7 Post(s)
Battery issue
hi, need help with a battery problem please.
Over the winter I fitted a new mosfet style reg/rec to my sp1, I tested the voltage at the battery after and it was putting out 14.5 at idle and the same at 4000 rpm I took it that this was ok. it might be worth mentioning the battery was disconnected for a few weeks prior to this point.
I have since ridden the bike several times adding up to about 5 hours in total no problems at all.
Today I go for a 45min ride and on way home call in at parents, went to leave and the battery was flat.
I put it on an optimate charger for a few hours and it brought the battery back to 12.8v and this was enough to start the bike.
I then tested the reg/rec voltage output at the battery again and now it is putting out 12.3 at idle and 12.7 at 4000 rpm.
Is this enough output from the reg/rec?
would a knackered battery cause the reg/rec output to be lower than before?
Battery is a YUASA YTZ12S and is about 2.5 years old and is usually on a optimate trickle charger.
Any help would be much appreciated.
Cheers
Wiffer is offline
post #2 of 17 (permalink) Old 05-25-2015, 06:35 PM
Quoted: 18 Post(s)
Check the stator output? Has one of windings caved or gone to ground?
Iloveyourgirlfriend is offline
post #3 of 17 (permalink) Old 05-26-2015, 05:27 AM Thread Starter
Wiffer's Avatar
Quoted: 7 Post(s)
cheers for the reply, i just had battery load tested and one cell is gone so new battery is on order. I have spoken to electrex world who supplied the R/R and they will test it for me tomorrow (only 5 miles from where I work) just to take that out of the equation and then i'll test the stator when new battery is fitted. At £85 for these batteries I want to make sure I have all areas covered
Wiffer is offline
post #4 of 17 (permalink) Old 05-27-2015, 04:41 AM Thread Starter
Wiffer's Avatar
Quoted: 7 Post(s)
Just a quick one, I take it that it is general practice to subtract the ohms resistance of my multimeter leads from my results when testing the stator resistance?
Wiffer is offline
post #5 of 17 (permalink) Old 05-27-2015, 06:58 AM
Quoted: 10 Post(s)
Ohmmeter doesn't read zero when you just touch them together? analog type meter/non digital? then you need to calibrate turn knob on meter to zero meter
avionicstech is offline
post #6 of 17 (permalink) Old 05-27-2015, 07:08 AM
The leads of a good Ohm meter don't read more than 0.5 Ohms.....usually 0.25 - 0.3
The three measurements on your three coils on your stator should read 2 - 2.5 Ohms on a cold engine that hasn't run for the past 8 hours at least.
Don't forget to measure the resistance between each of the coils and the engine. It should read nothing but infinite. Not a number, not a zero.
The real measurement though is the voltage between each pair of the stator cables.
Use AC over 50V scale and measure it at idle (around 20V AC) and at 5000 (more than 40V AC). The numbers are approximate. No engine produces the same numbers.
Here's a video I've made.....it might help
post #7 of 17 (permalink) Old 05-27-2015, 11:38 AM Thread Starter
Wiffer's Avatar
Quoted: 7 Post(s)
Thanks for the replies. Doesn't it say in the manual the three resistance measurements on the coils should between 0.2 - 0.5 ohms or are we talking about a different test?
Wiffer is offline
post #8 of 17 (permalink) Old 05-29-2015, 03:00 PM Thread Starter
Wiffer's Avatar
Quoted: 7 Post(s)
Well it looks like the battery died because my stator is knackered , voltage outputs across the phases at idle are 10 - 17 - 23 and at 4000rpm 25 - 35 -55, they are shorting to ground aswell. Had my reg/rec checked today and that's fine so that's one good thing I suppose. Will be checking my wiring from the stator for damage/shorts and if that's not the culprit I will be looking at getting the stator rewound for £120. As anyone had this done?
Wiffer is offline
post #9 of 17 (permalink) Old 05-29-2015, 03:16 PM
Sorry to hear that.
post #10 of 17 (permalink) Old 05-29-2015, 03:26 PM Thread Starter
Wiffer's Avatar
Quoted: 7 Post(s)
Yeah gutted, it might be the end of my riding for while as me and the mrs are expecting our 2nd child in a month, I was trying to cram as much in as I could. That's also why i'm looking at a cheap fix, most of my money is going on baby kit at the mo.
Wiffer is offline
