Tip sensor - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 20 (permalink) Old 05-31-2015, 01:14 PM Thread Starter
Send a message via Yahoo to vics51
Tip sensor
Where is the tip sensor located on the RC? And how are you able to reset it by just unplugging it and replug it again?
vics51 is offline
post #2 of 20 (permalink) Old 05-31-2015, 08:03 PM
Quoted: 7 Post(s)
The Tip Sensor is under the tail, close to the emgine. You cant miss it. It has an "up" marking on it and secured by two nut and bolts. No need to reset.
penn542 is offline
post #3 of 20 (permalink) Old 05-31-2015, 08:17 PM Thread Starter
Could it go bad after a low side? The bike was running fine it just lost spark or something and just shut off. She will crank but no fire.
vics51 is offline
post #4 of 20 (permalink) Old 06-01-2015, 08:54 PM
Quoted: 7 Post(s)
The tip sensor is pretty well protected, so I highly doubt that it was affected. You could have damaged something else on your lowside. How fast were you going when you bailed?
penn542 is offline
post #5 of 20 (permalink) Old 06-01-2015, 10:15 PM Thread Starter
I was turning into a road and hit sand and gravel. between 5-10mph
vics51 is offline
post #6 of 20 (permalink) Old 06-02-2015, 04:20 AM
Hanberg's Avatar
Maybe check the kickstand-switch?
Hanberg is offline
post #7 of 20 (permalink) Old 06-02-2015, 07:17 PM
Quoted: 7 Post(s)
Just throwing this out there, have you checked battery connections, which side did you lay down on, kill switch? Too many things to trouble shoot without more info.
Cheers
penn542 is offline
post #8 of 20 (permalink) Old 06-03-2015, 03:59 AM Thread Starter
I read in a different forum to disconnect the battery in order to reset the tip sensor. I haven't been able to mess with the bike so that's the first thing I'm going to try.
vics51 is offline
post #9 of 20 (permalink) Old 06-03-2015, 03:33 PM
Quoted: 7 Post(s)
Ok, hope it works out for you. Good luck
penn542 is offline
post #10 of 20 (permalink) Old 06-04-2015, 07:16 AM
Oz Rc51's Avatar
Can you hear the fuel pump priming??
Oz Rc51 is offline
