RC Hiccups - FI Cutting Out Under Certain Throttle Loads - Honda RC51 Forum : RC51 Motorcycle Forums
 2Likes
  • 2 Post By COBRA90GT
post #1 of 9 (permalink) Old 09-12-2015, 06:15 PM Thread Starter
MackerVTR's Avatar
Hey Guys,
I have some ideas about my problem, but wanted to hear from those more knowledgeable than I.
My bike is a 2003, PC3, fairly certain it has flapper and pair mods. I've only had it a year so not 100% on the state of some components. jardine exhaust, stock air filter, HID headlights. (all installed by previous owner)
My RC has recently started cutting out in various open throttle situations. The FI light comes on, the bike lurches to a hault for a second and then resumes normal business, it's as if it's not getting fuel for a second. The bike continues to run it just "hiccups" if you will. It seems to happen more frequently at certain RPMs dependent on the gear, but always under open throttle. The bike recently has also been harder to start (although not always) and my buddy reports my HID headlight turns on and off on occasion. The hard starts sometimes turn the display off and reset my trip computer. I've had the bike on a trickle charger constantly and I'm unsure if this has changed anything.
I do differential diagnosis for a living on people as a Physical Therapist, so I know in principle how to work through a problem. My gut says I have an FI issue, but there seems to be hints of electrical as well.
I'm actively searching through the forum, but thought I would offer this up to you wonderful and knowledgeable people on this forum for opinions in the meantime while I research/troubleshoot
2003 Honda ST1300A
2003 Honda VFR800
2003 Honda RC51 SP2
- Jardine Slip-Ons
- PCIII
- GPR V4 Steering Damper
- Vortex Clip-Ons
- CFMotorsports Rearsets
- Undertail w/ Integrated LED Brake/Blinkers
- Watson LED Front Markers
- Flapper/Soft Limiter/Pair Mods
MackerVTR is offline
post #2 of 9 (permalink) Old 09-12-2015, 10:05 PM
Disconnect the PCIII to see if the issue goes away. While you are going that, make sure your wiring harness is grounded well.
Since you are in Nova Scotia, salt air can give you corrosion issues. As you are inspecting your wiring harness, dielectric grease and a swab will do wonders to combat corrosion on/in your electrical connections.
post #3 of 9 (permalink) Old 09-13-2015, 12:50 AM Thread Starter
MackerVTR's Avatar
Thanks for the reply madbuyer, my first stop is definitely going to be the PC3, first reloading the map, and then disconnecting it completely if that doesn't work.
I've been reading a bit about the FPR failing in these bikes, when I try and search my topic. Does anyone know if my issue potentially fits into this category (ruling out the PC3?)
2003 Honda ST1300A
2003 Honda VFR800
2003 Honda RC51 SP2
- Jardine Slip-Ons
- PCIII
- Vortex Clip-Ons
post #4 of 9 (permalink) Old 09-13-2015, 04:03 AM
COBRA90GT's Avatar
Quoted: 47 Post(s)
Make sure your battery connections are tight btw...
kmblackbear06 and MackerVTR like this.
'06 Black/Metallic Gray RC51
-Competition Werkes FE w/
Clear Alternatives IT
'02 Silver/Black CBR 954RR
COBRA90GT is offline
post #5 of 9 (permalink) Old 09-13-2015, 09:58 AM
Have you checked for codes?
My gut reaction was maybe your throttle position sensor (code 8) or ignition pulse generator signal (code 19). You might check those connectors and wires.
Edit: I wouldn't suspect the fuel pressure regulator just yet. Doesn't' fit your description very well imo.
post #6 of 9 (permalink) Old 09-13-2015, 06:41 PM Thread Starter
MackerVTR's Avatar
Thanks for the reply Jon. I was thinking about checking for codes but although I've done lots of maintenance on my bikes, I've never had any of my bikes throw a code before - so I'm not sure exactly how I would go about checking. Will a standard automotive reader work?
2003 Honda ST1300A
2003 Honda VFR800
2003 Honda RC51 SP2
- Jardine Slip-Ons
- PCIII
- Vortex Clip-Ons
post #7 of 9 (permalink) Old 09-13-2015, 07:15 PM Thread Starter
MackerVTR's Avatar
So just randomly after I made my last response I googled "code reader" on the site and came across a thread started by user 'pnicho' in June that sounded remarkably similar to my issue. His issue turned out to be a loose battery terminal - you even commented in his thread Cobra that it seemed to be happening a lot lately.
I thought that was definitely worth a quick look, and sure enough the positive terminal was crazy loose!
It's evening here and raining, so I can't test the fix, but it sounds like that was definitely my problem. If this is common I wonder if it's the awkward angle the terminal screw is at... I put a quick disconnect on for my trickle charger and I recall it being quite awkward to get the terminal squared away again - and obviously I didn't do it right in the end
I'll post up as soon as I get a chance to ride the bike and confirm the issue is resolved.
I knew someone here would likely have a fix for me - Thank You Gentlemen!
2003 Honda ST1300A
2003 Honda VFR800
2003 Honda RC51 SP2
- Jardine Slip-Ons
- PCIII
- Vortex Clip-Ons
post #8 of 9 (permalink) Old 09-13-2015, 08:08 PM
Jake's Avatar
Quoted: 35 Post(s)
I had the same problem in the middle of nowhere out in Colorado. Only difference my rc got to the point where it was a dead stick. It too ended up being just a loose battery connection.
2014 December BOTM Winner
2015 June BOTM Winner
Still debating on whether to use my power of invisibility for good or evil
Jake is offline
post #9 of 9 (permalink) Old 09-18-2015, 12:41 AM Thread Starter
MackerVTR's Avatar
Finally got a chance to test the fix and the bike runs like a top - all issues resolved with tightening the battery lead
Thanks to all who replied!
2003 Honda ST1300A
2003 Honda VFR800
2003 Honda RC51 SP2
- Jardine Slip-Ons
- PCIII
- Vortex Clip-Ons
