how do i replace my map sensor on an sp2? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 8 (permalink) Old 10-12-2015, 02:13 PM Thread Starter
jgspecial's Avatar
Quoted: 46 Post(s)
how do i get to it? i cant find out enough info on the net to make me want to attempt it. one area shows the baro sensor on the snorkel another shows it near the throttle body. does anyone have pctures or at least can give me a breakdown on the easiest wy to replace it? the garage i went to said i have to replace it but they wanted to charge too much between the part and labor so i went the used route. any help would be much appreciated, thanks!!!!
jgspecial is offline
post #2 of 8 (permalink) Old 10-12-2015, 02:27 PM
Have you tried removing and refitting the connector. Sometimes it just needs a good cleaning, dielectric grease and plug it back on.
Are you getting a code from the FI lamp?
Here's a downlaoadable manual. Go to section 5-14
post #3 of 8 (permalink) Old 10-12-2015, 02:49 PM Thread Starter
jgspecial's Avatar
Quoted: 46 Post(s)
didnt even take it apart yet, thanks for the suggestions, ill probably look at it tomorrow.
post #4 of 8 (permalink) Old 10-12-2015, 06:19 PM
I think you should spend a little time testing what you have before automatically replacing it with a used unit...
post #5 of 8 (permalink) Old 10-12-2015, 08:47 PM
Quoted: 135 Post(s)
I can tell you that the MAP sensor is the same part on the intake and the throttle bodies, and they can go bad.
sbkdrew is offline
post #6 of 8 (permalink) Old 10-12-2015, 10:56 PM Thread Starter
jgspecial's Avatar
Quoted: 46 Post(s)
well im gettin a single long blink on the fi light the shop told me its the bad part and they specifically said map sensor and not baro. its nice to know its a common part between the 2. my question is, is the one on the throttle body accessible from the inside of the airbox? im new to working on my bike, sorry for the newbie sounding question but you guys seem to be very helpful and nice from the others ive seen you help. as always, thank you for the responses!
post #7 of 8 (permalink) Old 10-12-2015, 11:43 PM
Read the manual....you will need to remove the air box.
post #8 of 8 (permalink) Old 10-13-2015, 10:42 AM
SP1 you just need to lift the gas tank.
SP2 you need to also remove the airbox.
How long is that blink?
0.5 seconds = a short blink = 1
1.3 seconds = a long blink = 10
Sounds like you're on the right track with either the MAP or Baro.
Determine which code you actually have, then inspect the wires and clean the connectors.
Then clear the fault codes from the ECU's memory.
Then start the bike again and see if the code returns.
It may not.
If it does, then continue with the tests on page 5-14 and 5-15 of the service manual.
