recently purchased someone elses former track RC51 - Honda RC51 Forum : RC51 Motorcycle Forums
 6Likes
post #1 of 20 (permalink) Old 10-19-2015, 02:25 PM Thread Starter
It is in decent condition, but it has fiberglass race fairings which I am not a big fan of and I can't get any spark. Any help on the spark issue would be gratly appreciated.
Any idiot can twist thier wrist, it takes a man to pull the corners.
Hondarider is offline
post #2 of 20 (permalink) Old 10-21-2015, 08:27 AM
nitropolitan's Avatar
Quoted: 23 Post(s)
where have we checked for power? I know it's elementary, but check all your fuses right away.
Hondarider likes this.
nitropolitan is offline
post #3 of 20 (permalink) Old 10-21-2015, 02:10 PM
mydogiskooll's Avatar
Quoted: 4 Post(s)
Hey Hondarider welcome to the forums!
Does the fuel pump still prime as well as all other electronics? Remember when checking for spark that the plug needs to be grounded. Hold it against the block or the head while you crank the engine.
If you're certain that spark is the issue, then I'd start with the cheapest option first and replace the plug Then we get more pricey, digging into the coil, or seeing if he did any modifications to the ECU.
Let me know if'n you're trying to get rid of those fiberglass fairings cheap
Keep us updated!
Regards,
Drew
Garage:
1978 Suzuki GS550E (sold)
1980 Suzuki GS1000 (sold)
1985 Honda Elite 150 CH150 (stolen)
1987 Honda Elite 80 CH80
2000 Honda RVT1000R RC51 (project)
2007 Honda VFR800
Traveled over 10,000 miles on a trip around the USA
mydogiskooll is offline
post #4 of 20 (permalink) Old 10-21-2015, 03:15 PM
innovativems's Avatar
Quoted: 16 Post(s)
as DREW stated, if the pump isn't priming then check bas, and all sensors that would cut spark (kick stand, clutch).
innovativems is offline
post #5 of 20 (permalink) Old 10-23-2015, 08:07 AM Thread Starter
fuses all checked out
post #6 of 20 (permalink) Old 10-23-2015, 08:19 AM Thread Starter
I don't know if the fuel pump is priming, but the lights all come on and it turns over.
I have replaced the stator coil, the cdi box, and the voltage regulator/rectifier with parts out of running bikes.
Does the kickstand have to be up and clutch pulled in to start even when in nuetral?
post #7 of 20 (permalink) Old 10-23-2015, 08:22 AM Thread Starter
What is bas?
post #8 of 20 (permalink) Old 10-23-2015, 08:30 AM
mudduc's Avatar
Quoted: 19 Post(s)
Originally Posted by Hondarider View Post
What is bas?
That's what I was wondering.
You'll know if the pump primes because it whines for 3 seconds each time you turn the switch. Leave the switch on and toggle the run/stop to stop then run. Each time it is in "Run" position, the fuel pump will whine again for a few seconds.
Don't miss the fuse next to the regulator/rectifier on the left side under the tail and the main fuse (which must be ok given all the rest that's working) behind the battery. That single fuse by the Reg/Rec gave me troubles. It's been years but I remember it seeming like everything was working but got no spark.
Let us know if that was the burnt out fuse and what exactly were the symptoms (what was working and what wasn't) so my fuzzy memory will be refreshed for next time.
Hey, here's a picture of me on my track RC51 that I just found!
Later,
Kent Larson in Minnesota
mudduc is offline
post #9 of 20 (permalink) Old 10-23-2015, 08:49 AM Thread Starter
Sweet bike Kent,
The fuel pump doesn't prime.
The fuse by the reg/rect. under the red plug is ok.
post #10 of 20 (permalink) Old 10-23-2015, 08:55 AM Thread Starter
Drew,
I may be interested in dumping off the fiberglass fairing at a later date, but I wanna finish the bike first.
