gauge cluster memory question - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 7 (permalink) Old 06-02-2016, 09:48 PM Thread Starter
When you shut off and restart your bike, does the trip mileage rest automatically on you?
I had problems a couple years back with the speedo not working correctly. I purchased a replacement circuit board for the cluster off a member and installed it. When I did, I noticed that the trip meter would reset every time I shut the bike off. I just put the original back in today as I fixed the speedo problem (not gauge cluster related and had fixed it last year) and even my original does not keep the trip meter without resetting back to zero.
Is this how they all are and I'm just imagining things?
MikeinCtown is offline
post #2 of 7 (permalink) Old 06-02-2016, 10:09 PM
No, it keeps it trip mileage unyil manually reset.
SubSailor is online now
post #3 of 7 (permalink) Old 06-02-2016, 10:45 PM
Quoted: 326 Post(s)
you don't have power on the constant 12v to the dash for whatever reason.
or you have a loose battery connection
post #4 of 7 (permalink) Old 06-02-2016, 11:46 PM Thread Starter
Ok, that would be my issue then. Is this fused? I know when I found the speedo issue, it was because of some corrosion on one of the terminals. I'm wondering if I may have popped a fuse or something during the original inspection/repair.
post #5 of 7 (permalink) Old 06-03-2016, 12:29 AM Thread Starter
Think I found the page in the service manual with this info.
Blown 10A sub fuse which powers the Red/Green wire for the odometer.
Crossing my fingers. Thanks guys.
(it would figure I had the fairing off tonight and now it's back on. Why can't they put this stuff in a more accessible location)
post #6 of 7 (permalink) Old 06-03-2016, 10:51 AM
I had the exact same thing with my bike, it was the horrible grey connector. Here is the thread showing it.
https://www.rc51forums.com/forums/65-...resetting.html
boredcol is offline
post #7 of 7 (permalink) Old 06-03-2016, 06:47 PM Thread Starter
Actually that gray connector was the reason the speedometer initially didn't work. I cleaned it up with some QD contact cleaner and it worked like a champ. I must have popped the fuse when I cleaned it though. Pulled back the side panel and indeed it was the 10A fuse. New one in place and it works exactly as it should again!!!!
