Fuel overflow at top off - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 3 (permalink) Old 07-03-2016, 04:24 PM Thread Starter
Quoted: 8 Post(s)
After repairing the fuel tank leak at the rear mount, and replacing the FPR I now have a new fuel overflow issue.
Fuel will pour out from one the overflow tubes if I fill up. I can barely fill up to the top of the inner tank panel. This is the steel you can see directly under the fuel filler opening.
Is there some thing I could have missed during reassembly?
This did not happen prior. Not sure how much fuel I can put in as I haven't run it down low. The fuel will pour out of s tube. It is not leaking out of the tank. Once it bleeds off the excess it stops. No issues then.
Danoh1 is offline
post #2 of 3 (permalink) Old 09-23-2016, 04:00 PM
I just picked up an RC51 with this exact problem. Anyone have experience with this? I will continue to search the forums as well.
-CRASH-
-CRASH- is offline
post #3 of 3 (permalink) Old 09-24-2016, 12:11 AM
Sounds like you have a hole in the overflow tube inside the tank. Likely near the top of tank from the inside. Short of replacing, I don't really know a sound way to fix that.
