Fi code issues - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 11 (permalink) Old 12-18-2012, 02:43 PM Thread Starter
Fi code issues
Hey fellas, im having a problem with my SP2. I recently did some major overhaulin on my bike to create my version of the SP3. I am about 75% finished with my project. All that is left is to paint my race fairings and install my two 3in round headlights.
Today for the first time in about 3 months, I decided to fire up the bike. I could not before then because I have been working on it and everything was apart. The bike will start and run, however, I am getting some FI codes which in return are causing the bike to stall upon any revs. The bike idles fine and warms up fine but stalls out with any throttle pull. The codes I am getting are 8 short/1 long/1 short.
My recent project included the installation of an 05 CBR1000rr subframe, tail, and custom undertail exhaust. Needless to say all of my storage space disappeared and everything that was in the tail had to be repositioned around the bike so that it would all work.
Is there an FI code list for the RC51 or can anyone tell me what the codes me? The manual has nothing in it as I have read through it several times.
Your thoughts would be much appreciated.
LEDET409 is offline
post #2 of 11 (permalink) Old 12-18-2012, 03:18 PM
hmmmm Subsailor???? Care to chime in ??? He is a know it all LMAO
DuckHunterComposites
Duckhunter is offline
post #3 of 11 (permalink) Old 12-18-2012, 03:27 PM
Sniper's Avatar
in the rc manual section 5 - 12, gives you all the fi codes.
short blinks are 1, long blinks are 10, followed but a few short ones. then a pause between the next code.
8 short is loose or poorly connect TP sencer
1 long (just 10)is the baro sencer, thats on the front of the snorkel or top of air box.
unless its 1 long 1 short making it 11 which would be loose or disconnected speed sencer/ short in circuit/bad sencer.
2002 Honda RVT1000 RC51
Facebook
Sniper is offline
post #4 of 11 (permalink) Old 12-18-2012, 03:37 PM Thread Starter
When looking at the FI code as it blinks, it would show 8 short blinks, then a pause, followed by 1 long blink, then a pause, followed by 1 short blink. Hopefully that will better describe the issie.
LEDET409 is offline
post #5 of 11 (permalink) Old 12-18-2012, 04:10 PM
Depending on interpretation, it could be FI code 8 (TPS - Throttle Position Sensor), 10 (BARO sensor), and 1 (MAP sensor).
Or 8 (TPS) or 11 (Speed Sensor).
It's all a matter of the length of the pause between the 10 and 1.
But, that 8 code is TPS, and that could be the reason your bike runs badly when the throttle is rotated.
The ECU uses a default value of 0 deg throttle opening if there's a TPS sensor problem.
I would double check the connect or is making good contact and the contacts aren't corroded.
If all looks ok, then go through the troubleshooting routine to check the TPS in the service manual on P. 5-20.
post #6 of 11 (permalink) Old 12-18-2012, 04:38 PM Thread Starter
I dont understand it. I did not do anything to the bike put touch a couple of connectors underneath to move them around maybe an inch or two left and right just to see inside under the bottom of the tank. Now the bike runs with no problems. If it come back though, I will let you all know.
This bike is awesome but is so finicky in certain areas. At least that is what I have found since I have owned this the last three years.
LEDET409 is offline
post #7 of 11 (permalink) Old 12-18-2012, 04:54 PM
Not according to the manual. Error codes are shown ascending # order from the lowest #.
post #8 of 11 (permalink) Old 12-18-2012, 05:00 PM
This is very true about the interpretation.
However, considering that the TPS fault code is valid, I would stick with the MAP sensor too which is also located on the throttle bodies and say that the TB's wiring loom is not properly connected to the main wiring harness or some connectors are corroded on the 14p connector on the LH side of the rear cylinder (as you ride the bike), under the tank (the large one).
If that's true the the 10 blink (1 long flash) stands for the BARO sensor which is located on the air duct in the front (behind the dash) and it's either its connector on it or under the upper cowl's LH side the 2p connector (Light green/Black wire and Yellow/Red wire) poorly connected.
post #9 of 11 (permalink) Old 12-19-2012, 09:10 AM
How about some photos of this SP3?
Hanberg[DK] is offline
post #10 of 11 (permalink) Old 12-19-2012, 12:57 PM Thread Starter
I plan on doing a full write up on my version of the SP3 when I am finished.
LEDET409 is offline
