Track Day Prep - Page 2 - Honda RC51 Forum : RC51 Motorcycle Forums
 2Likes
post #11 of 22 (permalink) Old 03-29-2019, 08:22 AM
Quoted: 47 Post(s)
Where the seat and cover hook in to the front , under the round part of the sub frame , I put a piece of clear vinyl tubing around it to snug up the fit so mine wouldn't rattle.
Joe XR is online now
post #12 of 22 (permalink) Old 03-29-2019, 08:25 AM
Taping over the lights is as much about gluing together the fragile glass/plastic so it doesn't create a debris field in the event of a substantial get-off. Otherwise why bother worrying about headlights when no one has mirrors? Covering/defeating the taillight is about reducing the distraction, and resulting target fixation, for riders behind. Two recommendations - 1) use blue painters tape as it (generally) releases cleanly and won't leave your lenses all gooey. 2) Even with tape, defeat the headlight. It runs full time and may bake the tape, making removal more difficult. Have a fun and safe day out there!
Joe XR and jeosbor1 like this.
maxleanangle is offline
post #13 of 22 (permalink) Old 03-29-2019, 10:37 AM Thread Starter
jeosbor1's Avatar
Quoted: 13 Post(s)
Thanks everyone.....lots of good info!
2005 Honda RC51
2019 Ducati V4S Corse
jeosbor1 is offline
post #14 of 22 (permalink) Old 03-29-2019, 04:59 PM
10THbikE's Avatar
Quoted: 40 Post(s)
Originally Posted by Dutchy View Post
That rubber seal is meant to be used in combination with the seat pad. But if it fixed your issue then good too!
Two different parts Dutchy. One for the passenger seat described as "rubber, seat cowl" and separate part for cover "seal, seat panel" That last one is what he needs I think. Mine is about half gone but my panel always had a tight fit. Still have my passenger seat in the original box.
10THbikE is offline
post #15 of 22 (permalink) Old 03-30-2019, 07:32 PM
Dutchy's Avatar
Aye, you mean #9, I #25
https://www.bike-parts-honda.be/hond...__1700/2/11576
As for prep, do check your fluid levels as well...
Dutchy is offline
post #16 of 22 (permalink) Old 03-31-2019, 11:10 AM Thread Starter
jeosbor1's Avatar
Quoted: 13 Post(s)
I ordered both since I do not have either one
2005 Honda RC51
jeosbor1 is offline
post #17 of 22 (permalink) Old 03-31-2019, 07:18 PM
PlymptonRC51's Avatar
Quoted: 33 Post(s)
The #9 foam seal is paper thin, and will not take up any slop. I would check to make sure your locking mechanism is operating properly and holding seat cowl cover tightly. Would also add a longer bolt used to secure locking mechanism to sub frame and use loctite on bolt. Make sure you lift up on seat cowl as you tighten the franken bolts and two other screw head bolts. I also made aluminum brackets that go on my license plate mounting bolts and secure to the cross bar in subframe to help keep undertail from pulling seat cowl down. Could also use threaded rods that come off brake lights to attach little aluminum brackets and zip tie around cross bar that seat locking mechanism bolts to. Just worried about that option loosening up brake lights if have an aftermarket carbon undertail with brake light that is only weatherstripped in. But basically that #9 seal is just a very thin piece of foam and will not take up any space between cover and cowl, nice to have for paint protection, but that's about it.
PlymptonRC51 is offline
post #18 of 22 (permalink) Old 04-01-2019, 09:14 AM
Dutchy's Avatar
One more tip: get/stay in shape!!!
Dutchy is offline
post #19 of 22 (permalink) Old 04-01-2019, 09:33 AM
budoka's Avatar
Quoted: 56 Post(s)
Before I put track bodywork on my SP I used a spray on black plastic coating on the headlights. Got it at the local NAPA store. One of our other members used the spray black as well (where I got the idea). Easy to remove for street riding once the day is done.
'03 SP2, '09 GL1800
budoka is offline
post #20 of 22 (permalink) Old 04-01-2019, 09:46 AM
Quoted: 47 Post(s)
Aerosol Plasti-dip.
