Kickstand sensor - Honda RC51 Forum : RC51 Motorcycle Forums
 2Likes
post #1 of 12 (permalink) Old 10-07-2019, 07:32 AM Thread Starter
Just picked up a 2001 RC51 and the kickstand sensor was disconnected. I can't seem to find out where it gets plugged into. I must be overlooking it, but have no idea where to plug in. Will that also prevent the bike from starting?
Darin Gregory is offline
post #2 of 12 (permalink) Old 10-07-2019, 09:46 AM
Quoted: 326 Post(s)
It won't prevent the bike from starting so long as you're in neutral. It will prevent the engine from running when in gear though.
post #3 of 12 (permalink) Old 10-08-2019, 02:00 PM Thread Starter
Still cannot find where to plug in kickstand sensor into for 2001 RC51. Its not under the seat or behind, cable not long enough. Any one have any idea.
post #4 of 12 (permalink) Old 10-08-2019, 02:08 PM
Quoted: 326 Post(s)
It's in the boot by the coolant expansion tank iirc
post #5 of 12 (permalink) Old 10-08-2019, 02:42 PM Thread Starter
Thanks. I found the diagram, but it doesn't show where it ends. I wilk look this evening. Thanks again.
post #6 of 12 (permalink) Old 10-08-2019, 05:30 PM Thread Starter
Took expansion tank off, looked in rubber boot and no plug. Thinking its tucked in near engine and frame. Have no idea. Looked for a good hour.
post #7 of 12 (permalink) Old 10-08-2019, 07:25 PM
Quoted: 326 Post(s)
switch by William Glancy, on Flickr
post #8 of 12 (permalink) Old 10-09-2019, 06:23 AM Thread Starter
I have the diagram, but unfortunately I cannot locate the wire. Wondering if its tucked in somewhere.
post #9 of 12 (permalink) Old 10-09-2019, 08:25 AM
RC-DEVIL's Avatar
Quoted: 120 Post(s)
the kickstand sensor is a green small connector, usually to the left of the rear cylinder head. there is a bunch of other connectors near it.
if its not there and the bike still runs without a sensor, someone may have blanked it off.
1991 Honda HawkGT
2008 XR650L
RC-DEVIL is online now
post #10 of 12 (permalink) Old 10-09-2019, 08:32 AM
Quoted: 7 Post(s)
It should be exactly where Wibbly's diagram is pointing (top arrow pointing down). Mine was tucked in behind the frame and shielded by a clear rubber boot. Should have two wires and the connector is green I believe. If it was disconnected properly and the bike runs when in gear, there will be a jumper wire in the connector to allow the bike to run in gear. Hope that helps.
robertj1979 is offline
