Fuel line quick connect - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 7 (permalink) Old 02-10-2020, 09:12 PM Thread Starter
I know that taking my tank on and off will be a PITA. Especially if I will have to do it trackside. I would like to put in a quick connect fuel connector. I did a quick search here and found out that the info is now old and supplies are not available that are recommended from the thread on this site. I did a eBay search. I think the Motion Pro connectors are not able to be pressurized. I see Goodridge has connectors available but are a bit expensive.
I just found these
https://www.ebay.com/itm/BMW-R-K-Ser...53.m1438.l2649
I hope this link works.
Will this fit? Do I need a different size? Are the hose clamps a good idea or should I get them crimped on? Can I just transect my line or do I need to shorten it a bit to fit? I dont know the ID of the fuel line and I dont want to cut it in half in case I dont get the quick disconnect. Any experience will be greatly appreciated. Thanks
Jordan is offline
post #2 of 7 (permalink) Old 02-11-2020, 07:08 PM
GutsyToaster's Avatar
Quoted: 6 Post(s)
I was thinking of doing that as well and the link you provide seems to be the same thing I found...
https://www.jpcycles.com/product/350...nnect-coupling
Now I'm curious about the BMW fittings though.
Edit: This link is less money for two but there's absolutely no indication where they are coming from. Even their 'follow us' links only lead to the main pages. Sketchy.
https://www.rembusshop.com/bmw-r-k-s...-p-855966.html
GutsyToaster is offline
post #3 of 7 (permalink) Old 02-12-2020, 06:07 PM Thread Starter
The dealer from the link I posted has other sized fittings. If no one can say what the ID of our fuel line is, I may have to cut it and measure. I think the BMW fittings look good enough. Very similar to the Goodridge ones, but half the cost.
So does anyone know the fuel line ID? I may have to suck it up and cut it to figure this out.
Jordan is offline
post #4 of 7 (permalink) Old 02-12-2020, 07:26 PM
Quoted: 82 Post(s)
dansp1 is online now
post #5 of 7 (permalink) Old 02-12-2020, 08:23 PM
Quoted: 6 Post(s)
Yes, 5/16" is the right size.
post #6 of 7 (permalink) Old 02-15-2020, 08:10 PM
Quoted: 4 Post(s)
The ebay ad states that the couplers come with "2 fuel injection rated hose clamps."
Fuel Quick Disconnect Kit
The OEM fuel line is equipped with pressure fittings.
Any thoughts on whether a standard hose clamp will safely retain the normal fuel system pressure?
What about if the fuel pressure regulator fails, which is fairly common, and the fuel pressure spikes?
Current Rides:
2001 Honda RVT 1000R, SP1 - a.k.a. RC 51
* 90 Degree, Single Pin Crank, V-Twin
* World Superbike Championship, 2000 & 2002
* AMA Superbike Championship, 2002
2010 Aprilia RSV4 R
* 65 Degree, Dual Pin Crank, V-4
2017 Honda CBR 1000RR, ABS - a.k.a. Fireblade
* Flat Plane Crank, Inline Four
Previous Rides:
1990 Kawasaki ZX-10
* World's Fastest Production Bike When First Introduced
And a whole bunch of dirt bikes.
Enxss is offline
post #7 of 7 (permalink) Old Yesterday, 12:04 PM
Quoted: 47 Post(s)
Regular hose clamps would be fine.
Joe XR is offline
