Hey guys , I am in need for some help . My stator went on me and I ordered one from Partszilla . It came in yesterday so I replaced it along with the rectifier . Re installed the cover and filled with oil today . When I went to start it the only thing it does, is spin the starter motor. So my question is, do you think I F'd up my torque limiter gear / starter idle gear or the cover just didn't go on right ? Seemed to go on fine . Took me 3 times to seat it , and it seemed to seat properly . Got to come apart . Let me know what you think / tricks ….thanks
it
Yes Sir, I guess when I was re-installing I dropped the starter idler in the case cover . I had an issue when I was trying to get the cover . Every time I was trying to get the cover on square front and rear , lining it up .The rear of it kept pulling towards the magnetic flywheel and I kept pulling it back about 3 times . So what must of happened is I pulled the starter idler off . Thanks for asking John . What a PITA
My tip for the next time is get 2 lengths of M6 sized rod (or 2 say 80mm long bolts and saw of the heads).
Hand turn in the rods and use them to "guide" the cover in place. Put in a couple of the regular bolts and take the 2 rods out...
Thanks for that tip Dutchy . Thats just some common sense right there . I wish i thought of that, would of made it a lot simpler . Part of my issue was the pulse generator lead . I didn't want to break down everything ( rad , overflow etc ) just to do the stator . Do you guys remove the airbox to remove the pulse generator lead and then fish it back in ? Leaving it in place was probably stupid because it was so F'n short . In my mind I should of replaced that while i was in there . I did replace the reg/rectifier , even though it was still good . I like that Tip Dutchy .Thank you, would of really helped with the pull of that magnet keepin the cover angle str8
Related Threads
RC51 Forums
191.9K posts
10.5K members
Since 2008
