1 - 14 of 14 Posts
Ok first cluster lights stoped working after two wires touched in tail section I checked fuses but don't know what the problem is. If u know the problem or something to try let me know.
after checking fuses what did you find?
get a meter and check the fuses again. Maybe chech the main fuse closer to the battery
Well I just messed with the fuses and it started working. Now my other problem is I got no spark what do I check for that?
Did you pull one of the plug boots and insert an old plug just to see? (Thats why I keep old plugs around...)
Lights,fuel pump etc, everything works now?
No I just messed around with the fuses. But my first proble
Was I got no power to the fuel pump. I have checked relay and fuel pump it self. So it cones down the the bank angle sensor and I note it was wrecked before I for it. So do u think it's the bank angle sensor?
1 - 14 of 14 Posts
