1 - 11 of 11 Posts
When I tried to start my bike this morning, I turned on the key and got the expected fuel pump noise, headlight nice and bright, gauges went through the normal start up ritual, but when I push the start button it won't crank. The headlight turns off when the start button is pushed, as it should, but the starter does not engage. I don't even hear a "click" of a relay or solenoid. I hear absolutely nothing. I was in neutral with the clutch held in. I tried it with the kick stand up and down, in and out of neutral, clutch in and out, no difference. As soon as you release the start button the headlight comes back on. The gauge cluster never does loose power. I did toggle the handlebar kill switch a few times to see if it's the issue, but that didn't work either.
I had to jump in the car to get to work, so I haven't done any troubleshooting yet. I was hoping someone would have seen this before to save me from chasing wires all night tonight...
Thanks in advance!
Eric
Same thing happened once, ended up being the battery even though voltage looked good it would just drop off when I'd hit the starter. Other than that maybe the starter relay.
that isn't a starter fuse, that's the fuse for the whole bike. the starter isn't fused at all
first thing to check is for 12 volts on the coil side of the starter relay when you press the button. the troubleshooting path will be obvious once you do or don't have the signal to the relay
Hopefully I'll have time to get into it tonight. Where exactly is the starter relay located? Hopefully I don't have to pull the tail... The lower fairing is coming off anyway to replace chain and sprockets this weekend.
I had a few minutes last night, so I pulled the tail and found the relay. Nothing obvious wrong there, and when I short across the main lugs the bike cranks over. It's a little tough to check power to the relay when the start button is pushed since you have to unplug the connector to reach the connections. I'll make some jumpers tonight and print a wiring diagram so I can hopefully get to the bottom of this. My riding season is almost over and I'm missing it!
Problem identified. It's the start button on the handlebar. I made 3 jumper wires so I could get my volt meter between the starter relay and the connector. No power when the button was pushed, but I took my lead and bypassed the switch and it started right up. Next I took the handle of my screwdriver and gave the handlebar switch a little tap tap, now it works.
New switch on order, but it's not getting here till the 21st of the month. I guess bump starting is always an option...
if you pull the switch apart you'll be able to solder repair the connection. they are prone to failure.
typically it's the wire to the headlight that breaks, not the one to the starter relay.
Sure thing! I replaced the chain and sprockets while I had it on the stand as well. The previous owner put a Vortex aluminum rear sprocket on and it didn't hold up well at all. I went with "Driven" steel sprockets and a DID x-ring chain. Hopefully this set up lasts a long time!
1 - 11 of 11 Posts
