Good evening all,
I have a set of Akrapovic Ti/Carbon slip ons for my ‘03 SP2. They could use a repack but the factory kit (P-RPCK12) is proving to be a pain in the ass to find. Any suggestions for an alternative? I just want to make sure I have enough material to do the job. Thanks.
Thanks for the tip. Not sure if it matters or not, but is there a material density or thickness that works best? I was thinking the 1” thick blanket would work. Appreciate the advice.
The 1'' , you wrap it around as many times as possible and as tight as possible and either wrap wire or masking tape around it to hold it on while you work it into the can.
