1jcwallace, your PM setting need some adjusting, couldn't reply to you. So here it is.
1jcwallace said:
I finally ran across a set of SP2 headers for my my SP1. Now my question is what gaskets do I need to order? Do I just need the gaskets where the header bolts up to the manifold and if so, do I need Sp1 or Sp2 gaskets? And do I need any other gaskets for the headers? I thought I would ask you since you are one of the only few who have done the swap! Thanks
Are you doing a straight swap?
I don't know about the gaskets at the exhaust ports. I still have the SP1 part of the header there.
But yes - I would get new ones.
Try cross referencing the part numbers.
You may need to file or somehow mill off a little material from the SP2 header where it mates to the SP1 exhaust port.
Everything is checked as it should be. I really wish I could figure this out. I need the PM option available as I am becoming very active with my never ending search for parts!
