So after not riding/Starting my 02 SP2 up for 2 years. I finally got her running after replacing battery and the main fuse. I have all of the fairings removed and she is sitting at about 20,000 miles. Since I have all the fairings off was thinking of doing some general maintenance things. what maintenance things would you all look for/do? I'm already doing an oil change and replacing chain and sprockets.
Download the service manual and read the general maintenance and service schedule for suggestions. Lot's of them.
I was in a similar position just a couple months ago. I pulled the suspension front and rear and sent it in for revalve and respring for weight. I pulled the PAIR system off the bike. I did a coolant flush, changed the plugs, changed the oil, and cleaned and lubed the chain. That should get you started.
Mike
