I am showing about 120 MPH when doing about 40 MPH in my setup. Anyway to have this calibrated?
The only way to compensate for final sprocket ratios is to buy an Speedo-Healer.
It interconnects between the speed sensor (at the rear of the engine) and the Speedo Gauge/ECU.
You can then configure the final drive ratio and rear tire diameter
Or you can calibrate via GPS.
