dang that sucks, no replies...
I really couldn't find anything that would give a rise without modification to the fairing. So i elected to save my $300+ in my pocket and switch/flip the bars. Gave between an inch or two of rise. Much better on back and wrists. better for freeway riding. Still have to cut the fairing and bend out the fairing stay to make it all work. Need to clip off little tabs on the control units as well, or you can't screw down controls.
try this first, if you don't like it then spend the $... You'll probably have to cut fairings with any riser anyway.
good luck
I ordered the apex adjustable clip-ons without the riser. The clamp, I believe, comes straight out from the fork tube instead of down and then out like stock. This alone should give an inch or so rise, plus then you can adjust the bar up to straight out if you want. I'll see if this pans out when I get them.
