are you running the orginal axial mounted brackets or the radial brackets SBKDREW recently had made?
i think its 40mm axial and 108mm radial spacing for fitment
Berenger brake products are up there with the best. They are used a lot amongst the world endurance racing fraternity so they are used in the toughest of conditions.
ok you are running axial (originally supplied with the ohlins)
you would need 40mm spaced calipers
*edit that might be wrong maybe DH can point you in the right direction
