1 - 20 of 23 Posts
What would yield me a better performance gain for the money?
Sato Banzais or Turnone airbox and snorkel?
I already have the yoshi ems, flapper delete, pair delete, and soft rev delete.
Would I see any benefit from the turn one goodies while still running a stock exhaust?
Since an engine is a glorified pump, the greater the flow the better it is.
So I'd say pipe first, then airbox.
Of course you'll need a power commander to ensure the air/fuel ratio is set for 13.2:1 for best power.
good luck finding banzai's... great choice but very hard to find now
Discussion Starter · #4 ·
^how so? I thought sato banzais were easy to buy brand new?
sato has them listed on their site...
as does sportbiketrackgear
and dan kyle
Are sato banzai pipes hard to find now?? sub?
I have the yoshi ems so I am good as far as engine management goes
I have been looking at your exhaust for quite some time but to tell you the truth I am not a fan of the small cans. Do you have cans that are the same dimensions as the sato?
they are all built to your specs at Black Dragon
there are many sizes, shapes, and lengths as well as material options
also can do HRC size 98mm ones too
I have a 2-1 full exhaust in SS i can have a larger round, oval or even twin ballfe tri oval to go on too for you
They're not listed on Sato's site anymore. Only low mounts.
banzias = very high mount and those are completely sold out everywhere dan kyle himself can't get on for himself if he tired
the sato's low mounts are still out there and easy to get
good luck
its just a opinion but i hate the way these bikes look with 1 can. And I am dead set on a banzai style mount
i had a bonzai mount full exhaust made for me with small cans and i can have a high mount full 2-2 or even normal high mount slip-ons made with lager cans but for bonzai you might be out of luck
while I totally agree that exhaust is the way to go for a bigger gain I disagree that you need mapping to get gains from an airbox/snorkle mod. Now I will say you will get maximum gains with mapping but you should still see a bump in power from increasing airflow. Its similar to putting an intake on a car you will see a minimal gain from just bolting it on but if you can flash a chip for it to make the most out for the increased flow you can maximize resluts..
1 - 20 of 23 Posts
