Need help trying to figure out what happened. I was just getting on the highway and getting into 6th gear, when the engine just died. I went to restart, but it would not fire up and the battery was weak. I think I need a new battery anyway. Tried bump starting, but nothing. After a few attempts, the fuel pump would not prime anymore. Towed home. After a quick inspection, found a leak in the left side rad, near the top. Is there a low water level cut out switch? Everything ran awesome, except for an odd hint of anti freeze smell on the last 3-4 start ups, which I could never find and never lost any fluid. Any suggestions would be greatly appreciated.
Probably have a bad relay. Does the FI light come on when you flip the on off switch? If not then its a bad relay. There are 2 in the trunk you need to check. Take the one from your high beam and swap it out with the ones in the back and it should fire right up.
I checked the relay and could not find anything wrong. I tried to start it and it fired up right away. :confused::confused: I have no idea what was wrong. I appreciate the help. Cheers.
There's no coolant level sensor (other than your eyes).
My left radiator had a puncture from the previous owner, who patched it using using JB weld.
It didn't work. The expansion/contraction of the aluminum cracked the glue and my engine got up to 245 last summer, on the freeway.
So I had to have the radiator tank section heli-arched by a radiator shop that works on aluminum radiators. Since then, no coolant problems.
Also, since this bike has two radiators with associated hoses, it's important to periodically check and snug down the hose clamps.
Leaks at the left radiator are a common complaint.
Also, don't over fill the coolant overflow tank. It will leak past the cap and splatter along the frame section.
Just keep it more towards the middle of the level marks.
Making sure that you check the hose clamps at the top of each radiator periodically is good advice. I live in a seasonal climate (read: freezing in the winter) and due to the varying rates of expansion of rubber and various metals when the temps change dramatically, the antifreeze would weep out at these points. I would visit my bike in the dead of winter out in the garage, and a few times I would find a small pool of antifreeze on the floor underneath the chin.
Just a guess, but if you were running hard and hot for a long period, you may have boiled and evaporated the electrolyte fluid in your battery, and your hose clamps may have expanded on you too. Food for thought.
