when in the upright positon the fuel pump wont prime i hear a relay clicking switched it out with high beam relay and does the same thing when the bike is on the kick stand fuel pump primes and runs fine as soon as i sit on it bike cuts off please help
bypassed the bank angle sensor and it fixed that problem took it out and it wont pull pass 8000 rpm and stalled once when going around a slow turn
Which side of the bike is the relay on that you heard clicking?
When I turn my key on, I hear and feel both the fuel cuttoff and bank angle relay switches hit. So I think that's normal. The fuel cutoff relay should be in the bike's right side tailsection and the bank angle relay on the left. At the end of the subframe.
Here's the test for the bank angle sensor. Maybe that relay is cutting out on you.
