21 - 23 of 23 Posts
Discussion Starter #21
Finally problem fixed eventually somehow my gears were stuck I was able to get that fixed with the bike on stand spin rear wheel and shift up and down Thru all gears
if I put the bike in gear while on the stand and I lift the kick stand while in gear the bike won’t turn off and also if I shift into gear With the bike on stand it shift without using the clutch I put bike in gear and it start making a knocking noise the motor is healthy never had a problem prior to changing the chain the bike ran and shift perfect I’m trying to trouble shoot the problem and ones I get the problem fixed then I’ll keep you guys posted I just need to figure out what I did wrong after I replace the chain if I put everything back how it should be thanks to those who reach out To help
maybe ur chain dont match the sprocket, check to see ur new chain matches ur old sprocket. and also that ur distributor gave you the right part for your bike
21 - 23 of 23 Posts
