i just did the brake pads and brake fluid flush.now the lever and pedal go to the end before they stop i bleed them didnt see any air. any help would be awesome its the 03 sp2 thanks
when you do the zip tie do you oeave the cap off the resovierI hope you cleaned the outer pistons in the calipers before you pushed them in otherwise you will get chatter. Zip tie the brake lever overnight to get any air out and see if that helps. You did not bleed them correctly. After you zip tie is done wrap a rag around the banjo bolt at the master cylinder and pump the master and hold then open the banjo bolt to get any air out of their also. Do this until it improves.
