1 - 11 of 11 Posts
Whats the correct Brembo clutch master to use with the stock slave unit: 16 RCS or 19 RCS?
Also - anyone installed the Ladybird clutch switch LBP-CS1000 - that work Ok with the RCS clutch master?
Thx,
Don
For stock slave use a 16, for larger bore aftermarket use a 17
No I don't think the ladybird switch will work on the RCS. Use a pressure switch banjo bolt to retain the clutch switch.
Thanks Wibbly - I hadn't thought about using a pressure switch for the clutch - that's a good one. I am assuming the OEM clutch switch line has 2 wires? If I recall, some switches have 3 wires.
Thx,
Don
it's just two wires. it's just a bypass for the neutral switch via the kickstand switch.
the ECU does know about the position of it, so don't jumper it out.
I have a RCS 16 on my clutch and it is FANTASTIC over stock. Much lighter pull. I can get you a good price on Brembo stuff so if you're interested send me a PM.
Nick
1 - 11 of 11 Posts
