im trying to purchase pressure and dust seals for my 03 for both front calipers.
the preset on ron ayers or any other OEM dealer is "4" for each different seal.
if im doing both calipers should i change the quantity to "8".
the only thing that throws me off is that the part description says "piston seal SET"
i just dont want to under or over purchase parts. thanks guys.
you order 4 of 06451-MCZ-006 and 4 of 06451-MCJ-751. Each is a seal set for one piston. Has one piston seal and one dust seal. The drawing on the dealer web site can be confusing cause it only shows one caliper in an exploded view, but the quantities are for both calipers. edit I forgot you also need the 2 joint seals, one for each caliper. It's 45103-MR7-006. Recommend the stainless steel pad pins from Pro-Bolt as well.
