What model year? 02-06 your judder spring seat is flat if I recall and the judder spring is beveled. The friction disc with the skinny friction band goes next then alternate steels with the 5 identical friction plates. The last friction plate has a different color pads and green paint on one tab. So you will have 5 friction plates 22201-MAT-E00, one friction plate 22202-MAT-000 and one 22201-MAT-000. Disc “A” goes in first so it’s larger ID clears the judder spring. 2000-01 appears to not use the judder spring and 5 identical friction plates plus 2 disc A, one A disc at each end of the stack. Hope that’s fairly clear.
