1 - 20 of 20 Posts
Hey All,
I had a small leak on my 05' RC. I removed the left upper rad hose and a full litre and a half emptied out during the hose replacement procedure. I followed the instructions about running the engine and adding coolant at the rad cap hole. Yes, i blipped the throttle a few times. I added one litre of coolant as thats all I had and turned off the engine. Now, do i run the bike again and add fluid to the top of the rad or add half litre of coolant? It doesn't specify in the service manual.
Any info is appreciated.
Andrew is not a moderator (just one of many great members here) but this post might get moved.
I would check again at the radiator and then just top off the reserve. After that just keep an eye on the reserve.
Since you blipped the throttle a few times, I take that to mean you tried to burp the air out?
It takes a little more than that to effectively burp the cooling system.
The right way to do it, starting with a cold bike, is to have the bike on the sidestand, and have the rad cap off. Top of the radiator. Then start the bike and watch the coolant in the radiator.
As your bike warms up to right about 167F degrees, the coolant should start moving in the radiator. At 172F degrees, it'll be swirling around pretty good. Then you know your thermostat is completely open.
That's when to roll the throttle, I do it a little slower than actually blipping.
It could take several seconds or more for air bubbles to start showing up, if you have any. Be patient.
Once your satisfied theres no more air bubbles, turn off the bike, and let it cool down completely, 4 hours or more, then top off the coolant.
Then fill your overflow bottle to about 1/3 or 1/2 full. Might be a good time to make sure the overflow bottle is in good shape and overflow hose nice and clear.
Does that match up with the instructions you mentioned?
Fudbyaaff, otherwise gfy
No need to be hostile. You ask a question due to lack of reading the service manual then post the question in a wrong section, again, due to lack of reading, then respond with hostility when your called on it. I gave you the answer you were looking for without all the verbiage that you would have likely over read and missed if I had.
So CTFO :)
I've learned that some of the Canadian members are a touchy lot.
Except Kwtoxman, Nobody, and our favorite carbon/kevler Canadian, Duckhunter. They're great guys.
I thought you were from Canada when I read your reply Andrew. :p :p
Ok so I spent a good 5 minutes tryin to work out what Fudbyaaff meant and here's what I got.
That's right, nuthin... But gfy I do know lol
Me too. I've been holding off trying to give the benefit of the doubt.... especially for us rare canadian brethren.... even though it's hard. :D
Ditto if the case. Andrew is a good standing contributor. And I'm often pointing out obvious fluff posts with much more candour than this. Just sayin. ;)
There are definitely some touchy people here. Canadian included. Just look at some replies to me, where I show even more candour. :p
whhwnnantt?...burp. :D
:p It's all good
Thanks for the kind words sir...just sayin :)
Ok you guys are just making shit up to fuck with me now.. Gtftloy.
bahahaha. CTFO (chill the fuck out)
Discussion Starter #18
No hostility. The way I see it here is we can subtly chirp each other as we are RC brothers. I didn't mean to offend anyone, so GTGMOFOs!;-)
That last winter must have FYUPDB to give you such the red ass....why are you so anger?:eek::D
As they said in South Park "Blame Canada"
1 - 20 of 20 Posts
