My SP2 has an intermittent instrument issue that will probably cause me to run out of gas one of these days. Every now and then when I shut the bike off, the tripmeter resets itself to zero. Has anyone else had this happen, and any guidance as to troubleshooting?
Thanks!
Does this happen/ you notice just after starting? If so, check battery/ power connections. I had this happen a few times last year and I end up having to replace the battery (just not quite enough juice left after start up, to maintain memory). Good luck.
Thanks for the tip. I'm not sure when it occurs, but I notice it the next time I fire it up. My battery has been suspect for other reasons, and I may replace it.
