Error code list
132 Views 5 Replies 2 Participants Last post by  Garry Robinson
Good day All
Does anyone possibly have a list of the error codes and what they mean? It seems I may have a new gremlin lurking..
Any assistance much appreciated
Apologies I should have googled first, I did find one and it seems I have "Code-8" error. Anyone else experience this?
It seems it's related to the TPS or related wiring
Hello
Check these threads, i linked the most relevant post from each but you should read all the posts:
Thanks very much for that! When I snap the throttle open the bike sometimes surges quite severely, as if its losing 1 or both cylinders for a short moment. Its then that the light comes on with a code-8. The F1 light appears when surging under hard acceleration and then disappears on the next startup.
One other thing.. is this statement true?
"If the TPS is indeed bad, you'll have to replace the whole throttle body assembly.
The TPS can't be replaced as a component"
Do the simple checks first, clean tps connector/use dielectric grease to avoid short circuits/bad connections via humidity, disconnect Power Commander if installed, check your harness/connectors.
Unfortunately, regarding TPS replacement i know no other way than replacing the whole assembly. This is why:
Do the simple checks first, clean tps conector/use dielectric grease to avoid short circuits via humidity, disconnect Power Commander if installed, check your harness/connectors.
I'll do that, I live in a very humid climate so hopefully that does the trick.
Thanks for your help (y) I'll revert once solved
  • Like
Reactions: 1
