1 - 20 of 41 Posts
Hey gang....I am starting this thread to chronicle my before and after of getting a CF Airbox. This won't happen over night, but I will update as often as a I can and as $$$ allows.
Thus far here are the obstacles in my path
1st / Baseline Dyno Run - Going today to have this done - will post results
Airbox - Bidding on a pre-owned box now - Will post once I have it
Airbox Install - Will post once I can afford to have it installed
2nd / Dyno Tuning - Will post results
Mods so far - No "real" mods to speak of, but I want to make sure what I have done is documented for this experiment/experience
Soft Rev
D&D Full system
Flapper Mod
stay tuned !!
Kirk out....:cool:
Look forward to seeing the results sir and thank you for taking the time to do this.
Are you having the bike custom mapped with the current configuration before the airbox as well?
If the map you have now isn't optimized and then you do a custom map with the airbox then it is still not showing the actual gains from the airbox alone.
Wow...good feedback LDH...I hadn't thought of that. I will talk to the tuner and see if we can do a baseline today....get the box installed, do another pull and see what just installing the box did for me.
Then I will have the following -
Baseline Dyno Figures
Baseline Airbox Installed figures
Custom Map figures
That will give me 3 points of reference ....thoughts ?
That will work.
Ideally you really would want a custom map done with what you have and then another custom map done once the airbox is installed. The additional expense is hard to swallow and I don't blame you one bit for not wanting to follow through with that route, but that would be the most accurate way of discerning the gains in an apples to apples fashion.
That has been my issue all along with all the aftermarket airbox threads. I keep seeing 6-9 horsepower gains AFTER they add an Airbox and then they claim the airbox is responsible for the gains, but the dyno charts once the final tune is done look no better than the final charts I have seen or personally made with custom mapped Sato Slip-ons or Akra Full Systems with the stock airbox...
If the customer isn't optimizing the map and getting all the possible horsepower out of the bike to begin with, but then installing an aftermarket airbox along with a custom mapping that does get all the possible hp available then you get a false report of what the airbox is actually contributing to the final numbers.
Don't misconstrue I do believe the higher capacity of the aftermarket airbox should be a performance benefit, but I have not seen the actual numbers done in a way that truly verifies the results.
Just for the sake of it I should also point out that I have also falsely inflated numbers on an SP2 by forcing air from the blowers down its throat and altering the fuel map to compensate for it. The dyno chart was damn impressive, but in real life with actual windspeeds attainable through normal riding conditions the bike was so rich it almost instantly fouled the plugs and had virtually zero throttle response...
You could talk to DK and have DK Racing support this event :D
Who is DK ?? and hell yeah....anyone wanna throw me some money to move this along quicker...feel free to do so !!
LDH brings up a good point. One that I had always wondered about when seeing airbox dyno charts. But the same can be said for exhaust. Nobody ever goes and gets a bike with stock cans and a power commander tuned before they throw on a slip on and get that tuned. Sure they may pull a baseline with the stock exhaust and maybe the stock map from dyno jet, but it is the same situation. Inflated gains due to proper tuning on top of parts, and not just parts alone.
This is why you will never see an advertised "guaranteed" increase, only an "up to XXX more HP". All those maps you see on exhaust manufacturers websites and in magazines are after hours of tuning and fiddling to get the best numbers possible vs a stock off the floor bike.
Oh, and DK = Dan Kyle
I've actually given some thought to getting a map for the stock airbox, as i am not too sure how long I will keep the turn one box. I am planning on moving back to Seattle and am not as comfortable with an open style box in wet weather. I'm probably over thinking it though.
Ok...got the results.
123.89 HP ....will post the full Dyno Charts tomorrow
will do !!
Discussion Starter #14
Hi B Miller...I am waiting for him to email me the charts. No tweaks...just pull's
Discussion Starter #16 (Edited)
Hi guy's...just got this. I will swing by tonight w/ my flash drive and ask for all of the charts
@LDH - what email addy do you want these sent to ?
Discussion Starter #17
Discussion Starter #19
Hey LDH - Here is the other chart...shows all 3 runs until fall off
I wish i had gotten my charts from when i had mine tuned but he never gave them to me. next time i will get tuned and charts. But looks like my RC is getting a Major tear down and will become a year long project bike like so many others.
1 - 20 of 41 Posts
