Hello all,
Hoping someone has experience with the ignition switch bypass on an SP-1. Finally got around to doing the bypass mod via the Rogue site, and the fan doesn't operate now. I know the Sp1 fans operate off of a temp switch vs. the Sp2 which is switched through the ECU. I know I can just wire a manual switch in of course but on track I find myself often not exactly paying enough attention to the temp gauge and know I could easily miss it when its getting to that 220 range. Anyone have anything they can add?
Thanks!
did you connect the blue wire? there are three in the ignition switch. red is constant on, red/black feeds the bike, and the blue is for the fan. if you didn't tie the red/black and blue together the fan won't work.
Hey Wibbly,
No, just looked. I just looked and it appears I didn't. I'm sure that's the case though, looks like its solitary in the white connector that I used. It's wrapped and taped right now and I'm done for the night lol. Thanks so much man, I'll prob do it tomorrow and post results.
Wibbly,
OK, couldn't help it, had to dig a bit. So, the Bl w/Orange stripe needs to splice in with the red on the same side just giving it constant 12v? Sorry, guess I'm being a bit lazy man.
Excuse my ignorance but just want to verify before I go blowing fuses after soldering...essentially after the plug I created from that mod I just run a jumper from the red/blk on the other side of the connection to the blue/orange?
in order to turn the bike on, you need to connect the red to the red/black and blue/orange
in order to turn the bike off, you need to disconnect the red and the red/black and blue/orange
the blue/orange can stay connected to the red/black in all conditions
i have no idea what you are doing for a switch or how you have figured a way to do this, so talking about your "plug" doesn't help me. i'm just telling you what has to happen electrically.
