Just did the flapper valve mod, quick question the baro sensor is this supposed to be reattached or left off? the FI light is blinking unless its plugged in.
Yes, reconnect your MAP sensor. The FI needs it.
While you're at it, it would be a good time to put a dab of dielectric grease on the connector to prevent corrosion, moisture, etc.
second question doing the pair removal theres a small screw on the pair vale that wont allow the dan kyle cover to sit flush am i supposed to remove this grind it down or it isnt supposed to sit flush. im trying to ride tomorrow and my bike is in pieces HELP thanks guys
What do the installation instructions say?
I thought you removed the PAIR valve and installed the block-off plates.
Here's the link to RC51.org showing PAIR removal. http://www.rc51.org/pair.htm
ok so i just called dan kyle in the rc51.org instructions it says optional to remove the valve itself if you buy the block of plates everything must be removed the vavle the plate behind it. so its all good pick up some liquid gasket and be on my way.
