Good Morning,
This past winter I replaced the front brake pads and flushed the front brake system with Motul RF600 DOT 4 fluid. All was well.
After about 200 miles the front brake was getting soft despite the lever adjustment at 1. I bleed the front brakes again and all was well.
Now after another 200 miles they are getting soft again. I will bleed them again.
I see no leakage and the fluid level is at the normal level.
Do you think the master cylinder needs rebuilding? Is there a kit.
I appreciate any suggestions.
Thanks
KRR
PS I have a 2004, completely stock and would like to keep it stock.
I want to end the story. I checked the calipers, they were dry. I purchased a rebuild kit for the master cylinder ($35) and the brakes have been fine for the past two weeks. Found dirt and the main piston seal in the master cylinder looked worn.
Thank you
KRR
got my m/c rebuild and the brakes are still actting up. well the lever is. so i got a brembo m/c iam going to try. wish i had the same luck you did with your rebuild kit
