Talk to Jimmy Bell. Thermae Cooling. About $900 usd and you will have to source out your own oil lines and coolant hoses.
Alternatively you can run rad scoops on the side rads with the same results in cooling benefits as front mounts.
Have rad scoops, and still runs in the upper cooling range
Are push fans better
Thanks for being excellent source and I will be buying some stuff from you in near future
If your using puller fan setup with scoops then you likely will not see any benefits in cooling from the scoops. The scoops and pull fans are canceling each other out.
The scoops require air moving from inside out... While the puller fan is trying to counter that effect by moving air from outside to inside.
Switch over to a single spal pusher on the left and you will see much different results as the fan and scoops will now be a team effort and the removal of the rightside fan will allow for even more airflow.
  • Like
Reactions: gunny448976
