from a quick glance at my SP1, it seems like one would have to remove the clutch slave to get a good look at, check, count teeth or replace the front sprocket.
is this true?
thanks,
Paulie
PS: all i would like to do is count the teeth as i am trying to figure out my gearing. speedo seems off & trying to see exactly how many teeth on each sprocket. rear is easy, front seems not so much:eek:
aha!
Search man, search ;)
found it here with a nice diagram: remove 4 bolts, not 5th or i will have to bleed slave. great link on here with a pic. cant post the link because i am too new. i just had to search the rite phrase: RC51 front sprocket removal
i'm learning......;)
Oh yeah, well try of picture of your inspection.:D
And start whoring up some posts to get that count up, worked for me.;)
question on this...are there supposed to be dowl pins between the cover and the engine block, that the mounting bolts pass through?
Schematics show them, but seems my bike doesn't have them. However, the cover does fit flush and bolts can be torqued to spec.
Thanks,
B
