1 - 11 of 11 Posts
Remainder of parts I have, everything goes, starting here, then ebay...
Brakes
-Accossato front brake 19mm master cylinder with Brembo reservoir, never used
-Stock front brake master cylinder with lever, missing plunger rod
-Stock front brake master cylinder without lever
-Adjustable brake lever, blue, new
-SP-1 rotors stock (black), good, not over worn
-SP-2 rotors, stock (gold), not over worn - SOLD
-SP-2 aftermarket rotors, floating, silver, not over worn
-SP-2 front brake calipers, stock
-SP-1 rear brake and bracket, stock
Clutch
-Stock clutch master cylinder with reservoir and lever
Chassis
-Honda 1100 Black Bird kickstand (if you raise your rear, you'll like this)
-Passenger pillion cargo tray, mounts to stock tail fairing using stock latch
-SP-1 rear subframe (tail), straight
-Scotts damper, have frame mount, needs upper triple tree mount
-Tyga SP-2 upper triple tree, silver, does not include ignition key sub-bracket
-SP-2 stock upper triple tree, black
-1.5" raised steel handle bars with Throttlemeister - SOLD
-2 track handle bars, no dampers - SOLD
-Rear sprocket carrier, stock
-Front axle, stock
-Rear axle, stock
-SP-1 frame, black powder coated, good, straight, have title, includes both triple trees
Body parts
-Tyga carbon fiber front fender, new
-Side fairing louvers, carbon fiber
-SP-1 stock snorkel, converted to remove flapper
-Headlight, right side
-Windshield, dark tint
-Windshield, clear (looks like stock SP-1)
-Non-locking racing gas cap, blue, new in the box
-Stock mirror, right
-Stock mirror, left
-SP-2 upper fairing stay, aluminum, straight
Electronics
-SP-1 ECU
-SP-2 ECU - SOLD
-Power Commander II
-Dash
-SP-1 Harness - SOLD
-SP-2 harness - SOLD
-SP-2 race harness (stock harness paired back with coil on plug) - SOLD
-Regulator, stock
-Horn, stock
-Tip over sensor - 1 SOLD, 1 left
-coils with plug wires - SOLD
Engine
-SP-2 radiators, stock, with fans, not perfect, no holes or leaks
-SP-1 SPA fan mounts (Wibbley's nice mounts)
-SP-2 SPA fan mounts (Wibbley's nice mounts)
-SP-2 oil coolers
-Revolution racing cams/springs/retainers (cams used but low miles, rest new)
-PAIR block of plates, new
-SP-2 trans
-SP-1 trottle bodies - SOLD
-SP-2 throttle bodies
-SP-1 airbox
-SP-2 airbox
-DHC airbox, carbon fiber lid/fiberglass bottom, Moriwaki style but clears thermostat
-SP-2 complete engine, 500 miles, crated ready to ship or pickup
-SP-2 complete engine, out of track bike, ran good, willing to part out
-SP-1 with Moriwaki stage-2 cams/springs/retainers/ported by Moriwaki & HRC high compression pistons, willing to part out
Please PM on anything you're might be interested in....
All PMs caught up, working on shipments tomorrow...
Hi, PM sent.
I attempted to respond to your request, says correspondence is "closed" on that conversation...no idea why...I'm not doing shipping to Japan, you are welcome to arrange shipping and I can drop it off at a shipping hub if that helps you, sorry man...
OK don't worry. I checked FEDEX for the time being, but 75kg was expensive for personal air transportation ... Is it possible to use small items?
Have you considered a shipping container? It will take longer but if you can get into a container someone is filling, they're can be a lot cheaper...Which engine were you interested in?
HI, 500 mile SP2 engine.
Originally, a container (sea transportation) is ideal, but in my case it may be a little difficult because I need a transportation agent...
I'll do some research to study.
When I looked it up, it might be okay because there was an agent who would send it for about $ 550 for door-to-door container shipping (although it's a bit expensive for a container).
Please give us various details about the engine in PM.
1 - 11 of 11 Posts
