1 - 20 of 21 Posts
Ok 2000 rc51 the fuel pump will not prime. When i turn the key and then switch the kill switch to on I hear 1 click at a relay in the left tail section of the bike but fuel pump will not prime. Do you guys suggest a new fuel pump or other areas to check before i pull the fuel pump out? Also what size is the star or torx bit that is needed to remove the fuel line from the pump? thanks guys
I'm guessing that click you hear is the relay failing or a fuse snaping. I would start with that. I've heard them click or buzz. Go to the svc manual and go thru the fuel system section. Could be simple.
US version, Section 5-54. It tells you how to test the relay.
Determine which relay is actuating, whether it's the bank angle sensor relay or fuel cut relay.
The bank angle relay should actuate when the engine stop switch is set to Run.
When the bank angle sensor relay actuates, it completes half the circuit to actuate the fuel cut relay.
The ECU completes the circuit to energize the fuel cut relay coils and actuate the relay.
At that point the fuel pump motor energizes.
If both relays are actuated, and the pump doesn't run, then the fuel pump motor may be bad (actually the brushes inside may be worn out).
If you have downloaded the pdf version of the US RC51 service manual, go to page 5-52 to troubleshoot the fuel pump and both relay operation.
While you're at it, also download the UK service manual as the illustrations are better.
If the pump is bad, check Ben at RC51Parts.com to see if he has a fuel pump assembly on hand.
ok Thank you guys i was actually pulling the tank off and cannot get that last bolt under the seat. The relay that clicks is the one that is closes to the tail lights on the left hand side of the tail(bike). When the key is in the on position and i click the switch to run I hear 1 click. I went from off to run several times on the kill switch and each time i go to run i get 1 click. Also I would like to know if there is a way to check for engine codes? As I remember before the bike died on my buddy when he was riding the FI light came on earlier that week when he first started the bike. He then shut it off and started it bike up and the FI light was gone.
If your relay are still in the stock positions, ie no undertail mod, or maybe even if you do have an undertail, The relay you're hearing could be the bank angle relay. The manual shows it on the left and the fuel pump relay on the right end of subframe. I went back to 5-52 and started there, it looks like exactly what SubSailor said to do.
Does our fuel pumps keep running once the bike is on? I was thinking of wiring the fuel pump to a toggle switch, would this hurt anything if the fuel pump is always running? I ask because after taking the pump out and hooking it directly to the battery it works. But when i plug the pump back into the harness and switch the kill switch to run i just hear the relay click and no prime. Thanks again for the help.
The fuel pump runs continuously when the engine is running to maintain a constant pressure in the fuel rail
The fuel pressure regulator maintains and adjusts the fuel pressure depending on intake manifold pressure.
It would not be a good or safe thing to hard wire your pump to run continuously.
The purpose of the bank angle sensor is to shut off the fuel pump in case of a tip over or crash.
Here's a diagram of the bank angle sensor and fuel cut-off relays on an SP1.
When you set the engine stop switch to the Run position, the bank angle relay actuates.
The ECU is what actuates the fuel-cut off relay (with help from the bank angle relay).
If the bank angle relay is working and so is the fuel pump, it sounds like the either the fuel cut-out relay is bad, or a wiring problem may exist.
The headlight relay is the same 4-pole type. Try swapping the fuel cut-out relay with the headlight relay to test and see if the fuel pump switches on.
And yes, there is a way to check for FI codes on your bike, although it won't tell you a relay is bad.
There should be a green 2-pole connector in the rear section of your bike.
If you short the two poles and switch the key On, you should see the FI light flashing to indicate any stored codes.
A long (1.3 second) flash is a decimal 10 place, a short (.5 second) flash is a decimal 1 place.
The ECU shows all FI codes in order from smallest to largest.
ok thanks i removed the fuel cut relay and used a jumper wire on the connecter and the fuel pump kicks on. I replaced the relay with one on the front left side of bike and still no prime but maybe that relay is bad too. Looking for headlight relay now. Also does the fuel cut off relay control the bike starting besides the fuel pump? I tried to start the bike with the fuel cut off relay connecter jumped with the wire but no start. I think maybe the battery may be to low on juice.
Here's the location of the headlight relay.
Try swapping it with the fuel cut-off relay and see if the pump runs.
If that doesn't work, you may have wiring/connector problems or a bad ECU.
still no start and also i noticed when i pull the headlight relay the headlight is still on. I guess ill check for spark tonight. I read on the forum that a PCIII can stop the bike from starting so should i find where to unplug it and see if it the bike starts?
The headlight relay turns on the high beam.
Yes the power commander may be preventing the ECU from energizing the fuel cut-off relay.
Yes unhook the PC. I think the two plugs will be next to the frame, under the left rear of the tank.
Once you find the two big grey plugs, unplug them. Then you'll be holding 4 half plugs. or 2 male and 2 female. 1 of each belong to the bike's harness, and the other 2 belong to the PC's harness. Determine the male and female plug that belong to the bike's harness and plug them together. That will be the factory connection, which uses only the bike's ecm. The male and female plugs from the PC harness will just be laid to the side, don't plug them together.
The power commander basically interconnects between the two main fuel injector harness connectors to alter injector open duration.
With the PCIIIUSB, there are only two of these gray connectors and the negative battery lead.
With a PCIIIr, there's also the addition of a set of red pulse generator leads down between the front left engine mount inside a rubber sleeve with other connectors.
You'll need to disconnect those as well and reconnect the OEM red connectors or your engine won't crank with the gray PCIIIr connectors disconnected.
ok thank you. Well i tried that and still no spark. I guess next i will look at the cdi box.
Yeah, I saw you asking around. Good luck with finding some fire. When all else fails for me, I get a strong cup of coffee and start reading the appropriate sections of the serviec manual. I gotta say, that manual is very comprehensive.
You have the link for the PDF manual?
1 - 20 of 21 Posts
