1 - 12 of 12 Posts
went to the boneyard and swiped it off a VFR800 works/looks great :)
now all my bikes are the same (pattern reversed) and less confusing
well then it's even eaisier for you take your shifting knuckle of the transmission rod flip it 180 degrees so it points up bend your shift rod slightly so that it will pass the frame and there you go your bike is now gp shift pattern and you didn't even have to buy anything
Is yours GP shift pattern?
I had GP shift back in my racing days (so long ago...) and I just went back to it last night. Best mod ever, I think. The only time people miss a shift is upshifting, and GP shifting eliminates that.
Eric
Just a heads up this can be hard on your gears and internals. I recommend spending the 50bux and getting the Sato Conversion. It will work with the stock Rearset just be sure to adjust it correctly. I had this too, but changed over after going down on the left side at Mid Ohio and deciding to retain the linkage to keep the engine a tad longer. But yes, its WAY better.
Not sure if any year will fit, but if you are ordering one, you can use the part number below. You will have to re-use the pinch bolt and rubber cover from your stock shifter.
Eric
Honda OEM Reverse shift lever (GP Pattern)
24701-MAT-000 SHIFT, GEAR PEDAL
Quite a few people have done this and I haven't heard any negative reports. How is this harder on the gears and internals?
1 - 12 of 12 Posts
