Healtech speedo healer and gear indicator
371 Views 7 Replies 4 Participants Last post by  Fortysix&2
Hello, has anyone installed the indicator and Speedo healer together? How did you run the harness to the speed sensor since both units require that info. I can’t find a “Y” adapter for this setup.
Good question but Unfortunately i can’t help as I’ve only got the speedo healer installed on my bike but I’d like to know the answer to this then i can get a Gear indicator fitted so I’m following this👍
  • Like
Reactions: 1
I’m unable to find an adapter on the Healtech website to parallel the speed sensor circuit, I’m going to make my own using oem plugs.
Could you show how you’ve done it please
I’ll share the results 🤝
  • Like
Reactions: 1
I have the healtech speedo healer and the gear indicator. The install instructions are easy to follow.
After separating the Speed Sensor coupler, plug in both the male and female 3-pole GIpro harness connectors. Make sure the connectors are fully seated.
If you have a SpeedoHealer installed, you have to connect the plugs in-line in the following order:
Speed sensor male plug -> GIpro -> SH -> bike female plug
  • Like
Reactions: 2
Bro- thank you, much appreciated
