You mentioned the fuel pump, fpr and relays were swapped. Did this problem occur before or after any or those changes?
No. Pump doesn’t prime when the bike is hot. After I let it sit for an hour it will start again every time. I can only hear a click in the tank when it won’t prime.Do you hear the pump prime when you try a hot start?
That was my theory when I ordered the pump. Kinda like servos when they lock up and you have to tap them with something to get them spinning again. It’s just so consistent and easy to make happen again wondered if there was some thermal protection circuit that I didn’t know about. Thanks for backing my theory. I’ll just go ahead and swap the new pump in. 👍🏼Pump sounds like a cheap replacement. As it gets hot, the motor is locking up. The reason why you can keep riding when hot is because it’s already turning. But the moment it has to start from a dead stop, the motor isn’t strong enough. I’ve seen this on many vehicles as well.
What is the capacitor looking thing? The wire at the base is pretty bad. It’s the black and brown wire going in.Pump sounds like a cheap replacement. As it gets hot, the motor is locking up. The reason why you can keep riding when hot is because it’s already turning. But the moment it has to start from a dead stop, the motor isn’t strong enough. I’ve seen this on many vehicles as well.
Think the pump fixed it. Went on a decent ride and it started right up after she was hot. Will go for a longer ride tomorrow 🙌That was my theory when I ordered the pump. Kinda like servos when they lock up and you have to tap them with something to get them spinning again. It’s just so consistent and easy to make happen again wondered if there was some thermal protection circuit that I didn’t know about. Thanks for backing my theory. I’ll just go ahead and swap the new pump in. 👍🏼
Quantum Fuel Systems. Nice kit and shipped fast!Where did you get the new fuel pump from?
