No reason, they didn’t address any of the questions I asked at all. They just sent a shipping label. I think the back and fourth was maybe just an attempt to get me to go away? Either way, the Honda coolant shouldn’t pose an issue as it is HOAT coolant not an OAT which was the one they said would void the warranty. I plan to continue using Honda coolant and if it happens again, I’ll just ask for a refund.Did they give a reason why the u turn? Reason being i have some on order and have already purchased the Honda coolant, so are they saying it’s safe to use Hondas own coolant now?
Are you referring to vent hoses. If so I too am looking to replace vent hoses but I wasn't sure if they were 3mm of 4mm. Any advice?Ordered a set of Samco hose's, not sure if orig hose's on bike or not, so I will make sure she has fresh ones.
A little over $200, worth the price of knowing they wont blow out on me in the middle of nowhere.
Sorry for the delay response, no they are radiator hoses.Are you referring to vent hoses. If so I too am looking to replace vent hoses but I wasn't sure if they were 3mm of 4mm. Any advice?
I did have minor issue, the overflow line attachment point on the over flow tank, was unable to put the clamp on, not enough room for a clamp, did throw on a piece of safety wire.UPDATE, after the install did a test ride, 90 deg, it is running cooler, i would say 5 to 10 degs View attachment 138698 ooler,
A couple things....one, where did you get the case cover? looks clean. and two I was actually going to go blue hoses as well except you see how you have a single blue hose coming out of what looks like the coolant res? I want all of those hoses to be blue as well. just having a hard time finding what size hoses they are...I did have minor issue, the overflow line attachment point on the over flow tank, was unable to put the clamp on, not enough room for a clamp, did throw on a piece of safety wire.
The case cover is from EDR out of Beaverton Or, they were custom covers they used to make years ago. after getting all the fairing pieces back on, you don't get to see too much of the new ones. Size did not pay attention lol, I ordered my set through cycle gear.. Samco sells a kit for the RC... :}A couple things....one, where did you get the case cover? looks clean. and two I was actually going to go blue hoses as well except you see how you have a single blue hose coming out of what looks like the coolant res? I want all of those hoses to be blue as well. just having a hard time finding what size hoses they are...
