1 - 20 of 28 Posts
I'm curious, too. I'm not too far away from changing my stock-as-a-rock SP into one with Akra' slipons, a PC and (maybe)K&N's. The flapper valve mod' is a likely thing, too. The toss up on the K&N's is more due to those on here saying the standard filters are fine, and will flow enough air...
Either way, the plan is to dyno the standard set up for a base figure, then add the cans, PC and the base map to see how it looks, then tune it to 'just right' specs to get the final figure.
My initial impression of my bike, and having flashbacks to our old demo' bikes at the shop, is that they're 'strangled' from the factory to keep the wowsers happy, then we go and free 'em up... I can't wait for that big V Twin BOOM that I've missed so much!
ah yes, the v twin boom is special!!!
stock should be about 115-120hp.
i've got scorpions slip ons. in the next week or two i'm going to put on a k&n, new plugs, and do the flapper mod. then i'll be getting to the dyno. i'll let you know what it does. hopefully be able to post a graph.
i'll be happy withh 120.
ok here is the skinny. i have 2000 rc51,2brothers,k&n, done the flapper. just got back from bike night tonight. i dynoed and got 112.98hp
SOULD I BE HAPPY OR DISAPONITED!
VERY DISAPOINTED !!!!
That is extremely low. Do you have a power commander? It sounds to me like your bike is extremely out of tune for the mods you've done.
I was hoping that you would have a little more but maybe this is normal.
THIS IS NOT NORMAL IT SHOULD BE HIGHER
i just dynoed my bike. these are the numbers. they are about what i expected.
118hp at 9220rpm
69.3ftlb at 8114rpm
12.5-13 stoich readings(a/f)
112 seems a bit low. did you get your a/f readings? is your curve smooth?
pm me with an address and i'll send you my graph.
118hp at 9220rpm
69.3ftlb at 8114rpm
WHEN I DYNOED I ONLY GOT HP. DIDN'T WANT BIKE APART FOR FUEL AND AIR AND TORQUE BUT NEXT WEEK I WILL
i just pulled 113.89 in an All gear Tonight in school and I did a 4th gear roll on and pulled 113.67 All i have is a pc3 on it. next week some time i am going to put sato highmounts on and will run it again in class ill try for a torque reading also
Dan Kyle claims around 130 with the Sato low pipe and a Power Commander using his program. My bike has this setup, and it feels pretty good (no dyno yet), but clearly not in the ballpark with my 10R, which makes 160 RWHP and weighs around 35 pounds less. It sounds a lot better 'though.
Performance Bikes (UK) touted a tuner there who can get around 145 at the wheel for around $2200 US in mods.
my race bike makes 135 and change.
* Brand new SDS Performance motor in it. The motor has JE
high compression pistons, polished intakes, nice valve job, and lightened
crank. Soft limiter mod has been done and all the pair valve stuff is gone.
* 135.3 horsepower and 78 lbs/ft of torque.
* New clutch
* Yosh exhaust
* PCIIIR with a custom dyno tuned map by SDS Performance.
* GP Suspension front end
* Penske shock in the rear. The suspension is set up for 185-200 lb rider.
* Carbon Lorraine race pads up front with -2 braided lines.
* Woodcraft clip ons
* PP Tuning rear sets
* Billet clutch cover
* GPR steering damper and stay
1 - 20 of 28 Posts
