1 - 17 of 17 Posts
Hi so i got a pcll in a parts trade and when i install it on my sp2 the bike dies if i let go of the throttle. I contacted dynojett and they said its the wrong unit thats its for a vfr800 not an rc51. I dont know how they would know that when i never even told them the current map loaded on it. But my question is how would i know if they are correct or not
nope just said it was a pc2 and if it matters i did not splice it into the bike. it just plugged right in
also the map sticker on the back says m105-001 map . i looked andcant seem to find any maps close to that
I don't have a lot of experience with the PCII, however, did you load any maps to sync with the exhaust and air filters? You may have already done that, but you never know.
Yes i have got a couple maps to load that are for my upgrades but the bike keeps dying when i let off the throttle
heres a suggestion. how far is the idler turned up? may be a stupid question but sometimes it helps to start with the basics. you may be more advanced than me i was just trying to help. did the bike run fine before the pcII? is there a ground wire on the pcII harness? you said you just plugged her in. i noticed that ldh is saying you have an sp1 pcII, i guess theres your problem.
Yes when I bought it the guy told me it was map for an SP one I was just thinking I can load a new map onto it because it is for the RC51 order as the manufacturer is trying to tell me it's for the VFR as well as I will check the idle but it did run fine with the stock computer so can I just change the map to an SP2 map?
And yes there was a ground wire and yes I hook it directly to the battery on the negative side
you have to put a proper map in before you use it. if you haven't loaded a map why are you expecting it to work properly?
Discussion Starter #17
not sure if it helps at all but i took a couple pics the first 2 are of a map i can get to load although bike still wont stay running with this map it does load the second 2 are of a 114 map which is the sp2 map correct? which the tables are different and when i try to load it i get an error saying incompadable
1 - 17 of 17 Posts
